Выберете то, что вам нужно
Видео обзор
Hold down the home, power and volume up buttons.
Once the Samsung logo shows on the screen release the power button
You will then see a screen that says installing system updates followed by no command. Dont press anything during these screens just wait.
Once you have the following screen use the volume down button to highlight "Wipe Data / Factory Reset"
Press the power button to select it.
Do the same process to select yes on the next screen
You will then see confirmation at the bottom of the screen that the device has been wiped.
Press the volume up button and select "Reboot System Now"
The device will reboot and your done.
18 участников успешно повторили данное руководство.
7 Комментариев
Sistema resprinare
Nice bro hard
Thank you. Clear and precise.
Este tablet da empresa e está bloqueado e mesmo com o reset continua a não permitir o seu uso total, ficando sujeito apenas às APP que se instalam automaticamente... É possível resetar mesmo de raiz?
It still requires the original email login when it reboots however. So this is not a good fix.
