Введение
Loose screws and detached hinges can cause cabinet doors to become crooked. To some, this may look like a job for a contractor, but thankfully re-aligning a cabinet is a quick and easy fix that will save you time and money!
In this guide, I will show you a simple way to fix your crooked cabinet. The pictures demonstrate a cabinet with a soft-closing multi-adjustable door hinge.
Выберете то, что вам нужно
Open the cabinet door, and determine where it is misaligned.
Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
The result should look as pictured.
Еще один человек закончил это руководство.
