Введение
SCUF IMPACT - PLAYSTATION 4 CONTROLLERS
The instructions apply to all PLAYSTATION 4 SCUF controllers. Sway in analogs are caused by either damage to the controller or when the controller sensors are dirty. This problem will affect aiming when using the controller and the experience is not so fun. If the controller is in the good condition and you still have the sway in your analog(s), use the guide and follow the steps in order to fix the sway in your analog(s). The guide is pretty simple and there is no need for any special tools.
Выберете то, что вам нужно
Unlock the L3 or R3 ring by turning it counter clockwise.
Remove the L3 or R3 ring.
Dip the q-tip in rubbing alcohol to clean the sensor and inside the green box for any dust or dirt.
Еще один человек закончил это руководство.
3 Комментариев
HIGHLY RECOMMENDED! You saved my life. I have a lot of stick drift in my left analog that ruined my gaming experience through running movement in most of my games (Warzone, Apex, Fortnite) and this tutorial fix it ! I had some black crap on the sensor when I take them off and rubbing it with alcohol and a fine needle solve it. Thanks so much!!!
My green caps will not pop back on!!!
Did this and got the boxes back on but now my stick is broke. Just get stuck whenever moving it up or down and cannot be pressed down any more..
