Введение
Since eyeglasses are crucial instruments and must be worn almost all day, this can lead to various forms of wear and tear that can leave them bent or broken. If your eyeglasses are constantly falling off or seem crooked when placed onto your face, this guide can help you fix them at home so that they fit tightly and securely.
Выберете то, что вам нужно
Hold the temple and the end-piece of the eyeglasses together so that the screw-holes are aligned.
On a flat surface, carefully place the 1.4 mm slotted screw in the screw-hole.
On medium heat, blow a hairdryer onto the bent part of the glasses in order to make it more malleable.
Place the glasses on a flat surface. All four bottom points should be touching the ground.
