Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a pry bar to remove the pre-existing damaged wood pieces.
Start with the riser first.
Remove the treads on the stairs.
Use a measuring tape to measure the foundation where the new steps will be placed.
Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
Place the new piece of wood onto the end of a sturdy table.
Use a circular saw to cut across the straight line marked on the new piece of wood.
Place the new piece of wood (riser) on the steps to ensure that it fits.
Use a leveler to make sure that it is level.
Secure your wood piece (riser) into place using a drill and galvanized screws.
Create two pilot holes with the correct drill bit.
Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
Make sure your wood piece (tread) fits into place and is level.
Secure your wood piece (tread) into place using a drill and galvanized screws.
Create three pilot holes with the correct drill bit.
Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
Еще один человек закончил это руководство.
