Введение
If powder make-up is dropped it can crack. It's such a waste to throw out good make-up, so this guide will teach you how to salvage it.
Запчасти
  1. Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces. Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces. Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
    • Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
  2. Pour a small amount of rubbing alcohol into the cap. Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go. Do not use more than two caps worth of rubbing alcohol.
    • Pour a small amount of rubbing alcohol into the cap.
    • Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go.
    • Do not use more than two caps worth of rubbing alcohol.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface. The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
    • The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
  5. To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
    • To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
  6. Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
    • Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
    • If the powder is not fully dry, let it sit for another hour and continue to check back.
Заключение
These steps can be used to fix any type of powder makeup (ie. eyeshadows, blush, etc.)
2 участников успешно повторили данное руководство.
Meghan Smith
Участник с: 09.04.2015
224 Репутация
1 Guide authored
Команда
Cal Poly, Team 30-3, Green Spring 2015 Member of Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 членов
Автор 6 руководств
Один комментарий
It's also good to mash the surface down with something flat like a coin on top of a paper towel, while it's still a little malleable. This way, you get an even, similar texture as when it was new.
Great guide!
Kim Arre - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 6
За 30 дней: 32
За всё время: 977
