How to Fix Cracked Glassware with Food Safe Resin
Выберете то, что вам нужно
  1. How to Fix Cracked Glassware with Food Safe Resin, How to Fix Cracked Glassware with Food Safe Resin: шаг 1, изображение 1 из 1
    • Lay a garbage bag out on your workstation and put on disposable gloves.
    • Using separate cups, measure the resin and hardener to an exact 1:1 ratio.
    • Always wear gloves and ensure your work area is well-ventilated while working with resin. You may also want to wear safety glasses to protect your eyes.
  2. How to Fix Cracked Glassware with Food Safe Resin: шаг 2, изображение 1 из 2 How to Fix Cracked Glassware with Food Safe Resin: шаг 2, изображение 2 из 2
    • Add the resin and hardener to a container or bowl to mix the solution.
    • Scrape the sides of the measuring cups to ensure that both liquids are fully incorporated.
  3. How to Fix Cracked Glassware with Food Safe Resin: шаг 3, изображение 1 из 1
    • Use the mixing stick to stir the resin and hardener for at least three minutes.
    • Scrape the sides and bottom while mixing.
  4. How to Fix Cracked Glassware with Food Safe Resin: шаг 4, изображение 1 из 2 How to Fix Cracked Glassware with Food Safe Resin: шаг 4, изображение 2 из 2
    • Dip one end of the Q-Tip into the resin mixture. Submerging is not necessary; ensure the tip is coated enough to cover the surface of the crack.
    • Apply the resin mixture to the affected area(s), covering the crack completely. Cover both the inside and outside of the crack if necessary.
    • Be careful of loose shards of glass.
  5. How to Fix Cracked Glassware with Food Safe Resin: шаг 5, изображение 1 из 1
    • Allow the resin to cure for at least eight hours.
  6. How to Fix Cracked Glassware with Food Safe Resin: шаг 6, изображение 1 из 2 How to Fix Cracked Glassware with Food Safe Resin: шаг 6, изображение 2 из 2
    • Place the Q-tip and leftover resin into a disposable, sealable plastic bag.
    • Allow it to cure for 8+ hours before disposing.
    • Do NOT pour resin down the drain or into the sink.
    • Flip the measuring and mixing cups over the trash bag to remove any excess resin or hardener.
  7. How to Fix Cracked Glassware with Food Safe Resin: шаг 7, изображение 1 из 2 How to Fix Cracked Glassware with Food Safe Resin: шаг 7, изображение 2 из 2
    • When the resin has finished curing, use an alcohol wipe to remove any excess from the surface of your glass item.
    • If the resin is too hard, use a craft blade to gently scrape off the excess.
    • Exercise caution when working with blades.
  8. How to Fix Cracked Glassware with Food Safe Resin: шаг 8, изображение 1 из 2 How to Fix Cracked Glassware with Food Safe Resin: шаг 8, изображение 2 из 2
    • Pour warm water to ensure that the glassware is heat-safe and that the cracks are completely sealed.
    • Wash the glassware gently and thoroughly to remove any excess resin applied on the inside.
Финишная прямая
Еще один человек закончил это руководство.
Hana
Участник с: 10/16/24
181 Репутация
1 руководство автора
Команда
Austin Community College, Team 29-6, Watkins Fall 2024 Участник Austin Community College, Team 29-6, Watkins Fall 2024
AUSTINCC-WATKINS-F24S29G6
1 член
Автор 1 руководств
1 Комментарий к руководству
After applying resin, can I heat the item in open flame source ?
Jaggermeister Asti - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 29
За последние 30 дней: 160
За всё время: 1,242
