Введение
This guide shows how to fix Joy-Con drift for the Nintendo Switch Joy-Cons.
Joy-Con drift is when the Nintendo Switch thinks that the analog stick (also known as the joystick, controller stick, or thumbstick) of the Joy-Con is moving, but it isn't.
Joy-Con drift may occur as you use the Joy-Cons over time from dust and debris building up. You do not need to disassemble the Joy-Con for this repair. In addition, this guide will not corrode any parts of your Joy-Con controller.
Please note this repair is temporary and will last only a certain amount of time.
Выберете то, что вам нужно
Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
Insert the Joy-Con back into the Switch to test the Joy-Con.
Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
Follow the on-screen prompts on your Switch.
Enjoy your Joy-Con being able to work properly again!
20 участников успешно повторили данное руководство.
2 Комментариев
Muchas gracias.
