How to Fix Loose Temples on Plastic Framed Reading Glasses
Выберете то, что вам нужно
  1. How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 1, изображение 1 из 3 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 1, изображение 2 из 3 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 1, изображение 3 из 3
    • Fold the temples of the glasses inwards to feel which arm has less resistence.
  2. How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 2, изображение 1 из 1
    • Locate the hinge screw on the arm that had less give.
    • The steps to replace the screw will be the exact same for both hinges.
  3. How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 3, изображение 1 из 1
    • Test each screwdriver until the correct fit is found.
    • You may have to test every screwdriver to find the correct fit.
    • The screwdriver that we used was the #2 mm screwdriver.
  4. How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 4, изображение 1 из 3 How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 4, изображение 2 из 3 How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 4, изображение 3 из 3
    • Insert the correct screwdriver into the screw and gently apply pressure.
    • Turn the screwdriver counterclockwise to unscrew the screw.
  5. How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 5, изображение 1 из 1
    • Match the screw from the screwdriver kit.
    • Individually insert each screw into the eyeglasses. Different glasses use different screws.
  6. How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 6, изображение 1 из 1
    • Insert the correct screwdriver into the screw.
  7. How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 7, изображение 1 из 3 How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 7, изображение 2 из 3 How to Fix Loose Temples on Plastic Framed Reading Glasses: шаг 7, изображение 3 из 3
    • Turn the screwdriver clockwise to tighten.
    • Tighten the screw until you feel a slight resistance.
    • Do not over-tighten the screw.
Финишная черта
2 участников успешно повторили данное руководство.
John
Участник с: 09/28/21
181 Репутация
1 руководство автора
Команда
University of North Texas, Team 1-5, Raign Fall 2021 Участник University of North Texas, Team 1-5, Raign Fall 2021
UNT-RAIGN-F21S1G5
2 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 56
За последние 30 дней: 280
За всё время: 7,331
