Введение
Use this guide to repair semi-rimless glasses with a broken or loose retaining thread or lenses that have come out of the spectacles. This is a quick, simple repair. It can be done at home easily with tools like tweezers, fishing thread (as per the glass hole size), nail cutters, and scissors.
Выберете то, что вам нужно
Inspect frame to make certain the Monofilament Lens Retainer is broken. If the wire is not broken, your lens has fallen out and can easily be re-inserted. If the wire is broken refer to the following steps.
Hold the glasses in the position shown in the image. There will be a hole near the nose pad, shown by the arrow in the second photo, you will use this to insert the new wire.
Insert one end of the wire into the hole near the pad arm and insert the other end to the opposite side of the glasses, then tie the knot as shown in the images.
You will see a thin groove along the edge of the glasses. Carefully fix the wire around the groove as shown in the pictures.
After placing the wire around the glasses, stretch the wire, tie it, and make a knot by holding the glasses tightly.
In the end, check if your glasses are tight enough to wear. If the glasses are tight, they are ready to wear.
10 участников успешно повторили данное руководство.
9 Комментариев
I was just gonna comment this! Used floss and it worked great. Thank you for this article though, it was very helpful!
jcmills4 -
Using floss is a genius idea… combined with this article.
I don’t have the fishing line available (need to order it but that means days of wait), so I need a quick way to fix it (at least for short term).
Floss won’t work for the more authentic repair way (tightening without tying a knot), but it works well here as I have floss at home!
(yes a long term better fix is what HIK mentioned, but it requires a good measure of the thickness of the hole / string to ensure a tight fit)
I dont agree with above method, it will end in a very visible knot on both side of glass. The professional way is to pass the wire from one hole and again back in from another hole place the glass and stretch the wire on both sides, it will make it hold the glass tightly, no need for a knot. Just look at any half frame carefully and you will understand.
I was not aware frames came like this, right lens wire snapped, I see how to repair, but my hands are not steady, would a eye glass store help?
