How to Fix Snagged Jeans
Выберете то, что вам нужно
  1. How to Fix Snagged Jeans, How to Fix Snagged Jeans: шаг 1, изображение 1 из 3 How to Fix Snagged Jeans, How to Fix Snagged Jeans: шаг 1, изображение 2 из 3 How to Fix Snagged Jeans, How to Fix Snagged Jeans: шаг 1, изображение 3 из 3
    • Identify the snag that you would like to correct.
    • Insert the sharp end of your ballpoint needle through the centre of the snag.
    • Carefully turn the jeans inside out, while maintaining the placement of the ballpoint needle.
  2. How to Fix Snagged Jeans: шаг 2, изображение 1 из 2 How to Fix Snagged Jeans: шаг 2, изображение 2 из 2
    • Allow the ballpoint needle to stand vertically. This will happen naturally.
    • Take your No. 18 tapestry needle and gently maneuver all of the loose strings from the snagged denim to the inside of the jeans. You will position your needle to pull the loose strings upward.
    • Make sure there are no loose strings left outside of the jeans.
  3. How to Fix Snagged Jeans: шаг 3, изображение 1 из 2 How to Fix Snagged Jeans: шаг 3, изображение 2 из 2
    • String the No. 18 tapestry needle with your thread.
    • Tie both ends of the thread to form a small, tight knot.
  4. How to Fix Snagged Jeans: шаг 4, изображение 1 из 3 How to Fix Snagged Jeans: шаг 4, изображение 2 из 3 How to Fix Snagged Jeans: шаг 4, изображение 3 из 3
    • Make another knot, this time pull thread slowly and tightly around the snag.
    • Get the knot as close as possible to the surface of the denim jean.
    • Pull the knot as tight as possible.
  5. How to Fix Snagged Jeans: шаг 5, изображение 1 из 1
    • Use the scissors to trim the excess thread on both sides.
  6. How to Fix Snagged Jeans: шаг 6, изображение 1 из 1
    • Once you've removed the excess thread, take a small amount of fabric adhesive, and rub it against the knot you made to confident the snagged denim. The adhesive will secure the loose strings inside the denim.
    • Apply the adhesive so that the knot is stuck to the surface of the denim.
    • Allow the adhesive at least 20 minutes to dry.
  7. How to Fix Snagged Jeans: шаг 7, изображение 1 из 2 How to Fix Snagged Jeans: шаг 7, изображение 2 из 2
    • Turn the jeans right side out. The snag is no more!
Финишная черта
3 участников успешно повторили данное руководство.
Samantha Parison
Участник с: 01/19/16
182 Репутация
1 руководство автора
Команда
Oakland University, Team 6-1, Walwema Winter 2016 Участник Oakland University, Team 6-1, Walwema Winter 2016
OAK-WALWEMA-W16S6G1
10 членов
Автор 10 руководств
5 Комментариев
wtf?! make your nails first!
bettyanisko - Ответить
Exactly how do you determine which thread to pull on the reverse side of jeans??!! It was not obvious, and this ‘how to’ didn’t explain that essential part. Struggled for 15 min, then went on to another youtube how-to that worked easily (https://www.youtube.com/watch?v=--tHHF_M... ). With this other tutorial, I fixed two pairs in under 10 min.
Sherry Quinn - Ответить
I did have to try to find the strings (that were snagged) to pull through but with a little patience it worked beautifully! Thanks for the tutorial! I was proud of myself for finally using my little sowing kit! And people are jerks with the comments!
Karen Funk - Ответить
Thank you! This was helpful! I thought about fabric adhesive to secure the loose ends on the inside of the jeans, but so glad to know that you recommend it! Great photos!
Cheri - 5/31/2021
Cheri Johnson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 60
За последние 30 дней: 293
За всё время: 48,759
