Введение
This guide will help with fixing stripped screw holes from cabinet hinges, by securing those loose screws with anchors, a screwdriver, and a hammer.
Cabinets are held in place as long as their screws remain secured. However, with long term use of opening and closing cabinets, this results in a continual stress on the screws. This situation will create stripped screw holes, and it would be impossible to simply tighten the loose screws again. To simply solve this problem, just follow all the steps and the end result will be a nice and stable cabinet.
Выберете то, что вам нужно
Use a screwdriver to remove the screws from the stripped holes.
Take a screw from the cabinet hinge and use it to determine the appropriate size of screw anchor.
Secure the screw anchors within the hole by lightly tapping on them with a hammer.
Once the screw anchors are secured in place, align the cabinet hinges with the anchor holes.
Well done!
Well done!
2 участников успешно повторили данное руководство.
2 Комментариев
Boutje moertje door de wand is ook stevig
