Введение
This guide will cover how to fix a bent CPU socket pin on your motherboard. This will require a steady hand in order to carefully move the pins, since they are very small and fragile.
The reason for this fix is because motherboards with a bent CPU socket pin have trouble detecting the CPU itself. This fix can also be enable dual-channel, because there were a lot of problems enabling dual-channel memory for their computers.
The only requirements that is needed for this guide a needle, or any needles that is tiny enough to fix the pins (in my guide, I will be using a math compass, since I don’t have access to a needle), a workplace without any hazards such as electricity, and a steady hand.
Выберете то, что вам нужно
Place your motherboard on a table, or on any grounded surface that you are comfortable to work on.
Now, if you have an Intel Cooling Fan, turn the four pins on the CPU cooler counterclockwise.
Then pull all four pins to remove the CPU cooler off the motherboard.
Lift the metal clamp in order to remove the CPU itself. To do this particular step, there is a metal tab which you can push with a little force to carefully raise the metal clamp away after loosening the metal tab.
Use a needle and gently bend the CPU pins in the right direction where the other CPU pins are facing.
After fixing the pins, gently place your CPU with your thumb and middle finger into the socket.
Lock the CPU tray so that the CPU does not fall out of place. You will need a bit of force to push the lock.
Reinstall the CPU cooler and replace the four pins turning them clockwise to secure it to the motherboard.
Overall, this is the only way to fix of having the CPU undetectable from the motherboard, and enabling dual-channel memory. Some people have to RMA (Return Merchandise Authorization) or return their motherboard to their manufacturer, and receiving with a replacement. RMA’s may take time to receive their replacements, depending of the manufacturer.
6 человек успешно провели ремонт по этому руководству.
