Введение
The weather can be unexpected; therefore, it is important to always have an umbrella handy. Over time, umbrellas can sometimes break or not function properly. This guide will provide the necessary steps to fix a push-up button in an umbrella. It is a simple process that requires a thin piece of copper and permanent adhesive.
In step four be careful not to apply adhesive to your fingers, similarly, be mindful in step six when sliding the handle on, as you could accidentally pinch yourself.
Выберете то, что вам нужно
Remove the 1.1 mm screw that fixates the handle to the umbrella using a Phillips #1 screwdriver.
Place a thin malleable metal in between the button’s connection to the metal projection.
Apply permanent adhesive to secure the thin metal to the button's walls. Wait a few minutes for the adhesive to dry.
