Введение
With frequent daily uses, mouses can become dirty. A lag can occur between the mouse movements and what is displayed on the monitor screen. This is typically caused by a device inside the mouse call the optical sensor. The optical sensor gets dirty with frequent use and causes lag. Luckily, it’s very easy to fix! This guide will walk you through how to clean the optical sensor to reduce lagging, step-by-step. This fast-fix should take 10 minutes maximum. The tools needed include:
- Phillips head screwdriver
- Q-tips or a soft cloth
- 90% Isopropyl alcohol
Выберете то, что вам нужно
Start by flipping the mouse over to view the flat side of the mouse.
Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
To remove the flex cable, gently pull the cable clip until it becomes unlatched.
Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 участников успешно повторили данное руководство.
2 Комментариев
why did you opened it if you just cleaned eye with alcohol
