How to Fix a Dirty Censor in a Corsair Harpoon RGB
Выберете то, что вам нужно
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 1, изображение 1 из 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 1, изображение 2 из 2
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 2, изображение 1 из 3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 2, изображение 2 из 3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 2, изображение 3 из 3
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 3, изображение 1 из 1
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 4, изображение 1 из 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 4, изображение 2 из 2
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 5, изображение 1 из 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: шаг 5, изображение 2 из 2
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
Заключение
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 участников успешно повторили данное руководство.
Kady Volmering
Участник с: 03/16/21
200 Репутация
1 руководство автора
Команда
2 Комментариев
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - Ответить
why did you opened it if you just cleaned eye with alcohol
antoncoinz - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 30
За последние 30 дней: 172
За всё время: 5,962
