Введение
If you have a pair of cotton leggings that have developed holes, use this guide to repair the hole by hand sewing.
When leggings develop holes, they are often thrown in the trash because they cannot be worn. But these holes can be easily repaired, even if they are not located on a seam!
Before using this guide, inspect the leggings to locate all holes, as this guide can be repeated if needed.
Выберете то, что вам нужно
Use scissors to cut a piece of thread that is the color of your leggings at least 12 inches long.
Thread the needle by running the piece of thread through the eye, or opening, of the needle.
Pull the thread through the needle until there are two equal halves of thread.
Tie a knot with the ends of the thread.
Tie a knot using the tied ends of the thread (at the beginning of the hole) and the thread still attached to the needle (at the end of the hole).
2 участников успешно повторили данное руководство.
