Введение
On some Xbox One controllers, the main buttons can become jammed or non-responsive overtime. This guide is made to help with this problem in order to avoid having to constantly buy new controllers. This guide will help you fix a stuck or jammed button on your Xbox One Controller (Model 1697).
Выберете то, что вам нужно
Using a prying tool, unclip and remove the back parts of each handle.
Remove the battery in the center of the back panel.
Using a TR9 Torx screwdriver, remove the top and bottom screw of each handle and the one screw within the battery area (five screws total).
Remove the front and back plate of the controller by pulling them apart.
Carefully remove the right and left thumbsticks by pulling them off of the controller.
Using your hands or a prying tool, gently remove the top bumper strip from the top of the controller.
Using a TR6 Torx screwdriver, remove the two screws on the top motherboard and unclip it.
Using the TR6 Torx screwdriver, remove the six screws on the bottom motherboard.
Carefully remove the motherboard from the controller.
Remove the rubber button cover holding the buttons in the controller.
Once the cover has been removed, flip the controller over to dump out all the plastic buttons.
While holding a q-tip, gently pour a small amount of rubbing alcohol onto the q-tip.
Use the the q-tip to rub the inside where the buttons go in order to clean out any debris or dirt that might be in there.
5 участников успешно повторили данное руководство.
