Введение
Water is leaking at the connection between the shower head and the pipe? No problem! Here are some simple steps to fix it!
Выберете то, что вам нужно
Use a ruler to measure about 8" long on the teflon tape. Then use a pair of scissors to cut it.
Place the wrench on the shower head mount. Adjust the wrench to fit tightly on the mount.
Turn the wrench counter-clockwise to loosen the showerhead, then unscrew it the rest of the way by hand to remove it.
Place and hold one end of the tape on the threads at the end of the shower arm (the pipe coming out of the wall).
While taking care to keep the tape flat, wrap it clockwise around the threads, completely covering them and wrapping back over itself to stick.
Thread the showerhead back onto the shower arm.
Spin it on a few times to get it hand tight.
Test out the showerhead with your hand tightening first. If it still leaks, you may need to wrench on it a bit to seal things up.
The tape is replaced! However this may not have solved your problem. If the showerhead still leaks from the joint with the shower arm, there may be dirt or debris in the joint, or damaged threads on the shower arm.
Try tightening the showerhead a little more with your wrench, or reapplying teflon tape to ensure a good layer.
This guide is made to maintain the tightened connection between the shower head and the pipe. If the shower head is leaking water elsewhere except at the connection, please seek for other fixing guides for repairing shower head leaking problem.
6 участников успешно повторили данное руководство.
4 Комментариев
I found the rubber washer was missing on the end of the hose so I put a 1/4" rubber grommet and it just happened to squish in the middle for a leak-less connection.
My shower head is leaky in it’s joint and it’s not possible to wrap this place with tape. Water is dripping from the joint and it looks odd. Is there any solution for this or should I replace the shower head with a new one.
I have handheld shower head with slide bar, I tried the above method but still, sometimes it drips. Do you have other methods for shower leakage issues?
This was my first experience trying to repair a leaking kitchen faucet. I used a few different tips and tricks to fix the problem, but none worked. I tried to fix the problem myself and the only thing that worked was to replace the entire faucet assembly.
