Введение
Use this guide to fix the wobbly and squeaky arm rests for your “ Living Polyurethane Split Leather” Office Chair (model 068-0935-6).
When you have an office chair for work purposes and it has been over a few years since you got that chair, your arm rest starts becoming wobbly and noisy. It is usually the loose screws and dust particles that make it wobbly and squeaky. Follow this guide to remove the arm rests, clean the screw holes, and reassemble your chair—you won’t have loose arm rests when you’re through!
Выберете то, что вам нужно
Use a hex key to undo all of the M3 x 6 mm alloy steel hex bolts.
Turn the hex key in the counter-clockwise direction to unscrew the bolts.
Adjust the arm so that each hole is aligned with the hole where the bolt goes in as shown in the picture.
Reassemble the arm rest and place the the bolts back as they were.
To tighten the bolts, turn the hex key in a clockwise direction.
Tighten the bolts and check to see if they are tight enough.
Check the arm rests to see if they are stiff and not wobbly
Check each bolt and tighten till the arm rest isn't wobbly.
3 Комментариев
Suppose that the bolt is not hex or phillips or star, but is completely smooth and the fabric is closed with stitching. After removing the caps that cover the holes in the arm there is just a completely smooth bolt or screw with no way to grip or turn it?????
