Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Before you begin:
For this fix, you would need to find a specialized screwdriver that would fit into you oven door handle screws. Have a damp cloth at hand if the screws are needed to be cleaned. If during your observation you notice that the screws are damaged you may need to buy new ones.
Запчасти
Детали не указаны.
  1. Open the oven and unlock hinges that are located at the bottom of each side of the oven. Open the oven and unlock hinges that are located at the bottom of each side of the oven.
    • Open the oven and unlock hinges that are located at the bottom of each side of the oven.
  2. Lift the door up and detach from the oven. Place the door on the floor or any other flat surface.
    • Lift the door up and detach from the oven.
    • Place the door on the floor or any other flat surface.
  3. Unfasten the top 2 screws of the inside of the door ( the ones holding the handle). For this specific oven, a Phillips #0 screwdriver was used. Make sure to check which screw driver fits your oven screws.
    • Unfasten the top 2 screws of the inside of the door ( the ones holding the handle).
    • For this specific oven, a Phillips #0 screwdriver was used. Make sure to check which screw driver fits your oven screws.
  4. Observe the screws.
    • Observe the screws.
    • If rusty, cleanse them. If damaged, replace with new ones.
  5. Reset and fasten the screws back in tightly.
    • Reset and fasten the screws back in tightly.
  6. Place the door back to the oven. Refasten the hinges.
    • Place the door back to the oven.
    • Refasten the hinges.
  7. Test the handle
    • Test the handle
Заключение
Еще один человек закончил это руководство.
Viktoria
Участник с: 22.01.2019
172 Репутация
1 руководство автора
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 20
За последние 7 дней: 127
За последние 30 дней: 662
За всё время: 8,536
