Введение
These steps encompass most of the breaks you might encounter in a wooden papasan chair base. It is a quick and simple set of repairs that will allow you to enjoy your papasan chair for many years to come.
Выберете то, что вам нужно
Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
Screw the circular base and upper to the vertical supports that have become disconnected.
Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
Following these steps will restore your papasan chair to working order.
6 участников успешно повторили данное руководство.
3 Комментариев
What screw you used? Screw dimensions?
easy peasy…thanks
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
