Введение
Having a broken/ripped toy isn't much fun. So these instructions will help you fix your beloved stuffed animal.
In this case, a stuffed bear has been ripped by its legs and has lost some of it's stuffing. We will go step-by-step on how to refill it with stuffing and sew it up.
Выберете то, что вам нужно
Use Polyester Fiberfill stuffing to fill the stuffed bear via rip. Add more stuffing for a firmer toy.
Insert a thread through the eye of the needle (the hole) and tie it tightly to the needle.
Push needle through the end of the rip.
Continue along the seam, putting the needle through both sides of the rip to create a stitch.
After the rip is sewn shut, tie the end of the thread by creating a knot
Create the knot by wrapping the thread around the needle several times Then pull the thread through to secure the knot at the base.
Once is enough, but for more security, you can repeat this step twice.
