Введение
We as humans tend to be clumsy, which can lead to many things breaking. For example, a ceramic piece that can have sentimental value. Here is my guide to fixing the ceramic piece using simple tools.
Выберете то, что вам нужно
Gather all the pieces and dust them off using the toothbrush. This way there is no stray shards left on the pieces.
Lay all the pieces on a towel or clean surface, aligned with where they belong. This way it is easy to find what you need in a timely manner.
Using the largest piece as the base for the repair, start gluing the pieces back where they belong. Make sure to not overuse the glue, as it can cause issues later.
As you glue each piece make sure to hold it in place until it solidifies enough to hold everything in place, then glue on the next piece.
After you glue it back together, allow it to dry. This way the glue has time to set in place and harden.
