How to Fix a Stuck Trombone Tuning Slide
Выберете то, что вам нужно
  1. How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: шаг 1, изображение 1 из 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: шаг 1, изображение 2 из 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: шаг 1, изображение 3 из 3
    • Carefully remove the slides from the trombone.
    • If the slides are completely stuck, wiggle the slides from side to side while pulling it out of the trombone.
  2. How to Fix a Stuck Trombone Tuning Slide: шаг 2, изображение 1 из 1
    • Clean each slide using a paper towel or cloth.
    • This will remove any friction the slides may have with the trombone.
  3. How to Fix a Stuck Trombone Tuning Slide: шаг 3, изображение 1 из 1
    • Check to see if the tuning slides are parallel with their corresponding parts.
    • This can be done simply by aligning the slides against the trombone.
  4. How to Fix a Stuck Trombone Tuning Slide: шаг 4, изображение 1 из 2 How to Fix a Stuck Trombone Tuning Slide: шаг 4, изображение 2 из 2
    • If the slides are parallel, skip to step six. If not, attach each individual slide to the trombone and push/pull in the direction in which it would be parallel.
    • This will straighten the warped slides back into place.
    • Warped slides can be very difficult to move when attached to the trombone.
  5. How to Fix a Stuck Trombone Tuning Slide: шаг 5, изображение 1 из 2 How to Fix a Stuck Trombone Tuning Slide: шаг 5, изображение 2 из 2
    • Check to see if the slides are align once more.
    • Keep repeating step 4 if the slides are not lined up yet.
  6. How to Fix a Stuck Trombone Tuning Slide: шаг 6, изображение 1 из 2 How to Fix a Stuck Trombone Tuning Slide: шаг 6, изображение 2 из 2
    • Apply tuning slide grease to each slide.
    • Make sure each slide only gets a thin layer of grease. Too much grease could cause friction when attached to the trombone.
  7. How to Fix a Stuck Trombone Tuning Slide: шаг 7, изображение 1 из 1
    • Attach the slides back to the trombone.
    • Position the slides to your liking and enjoy playing!
Финишная черта
Еще один человек закончил это руководство.
Nolan Robinson
Участник с: 02/27/18
172 Репутация
1 руководство автора
Команда
University of Memphis, Team S4-G5, Baddour Spring 2018 Участник University of Memphis, Team S4-G5, Baddour Spring 2018
UM-BADDOUR-S18S4G5
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 2,018
