Введение
If your Manual Recliner Hydraulic Barber chair has issues with the balance, use this guide to assess and repair the problem.
The problem with an unbalanced hydraulic chair tends to be an issue with the base of the chair, usually due to missing or damaged screws.
This guide is simple enough that anyone with no experience in repair will be able to follow through to the end and achieve the result they wish.
Before beginning, make sure that you have another person to lend a hand as the seat of the chair might be too heavy for one person.
Выберете то, что вам нужно
The issue with the barber chair is located at the base, where the screws have come loose.
Use your foot to repeatedly pump the hydraulic height-adjustment pedal under the chair until the chair reaches max height.
While holding the pedal down with your foot, grab both arm rests and pull the chair upwards.
Place a screw with a washer attached into a hole and tighten it with a 7/32" hex bit.
Repeat this process for the other 5 screws and washers.
Align the bottom of the seat with the top of the pole, and gently put it back into position.
Make sure the seat is properly fitted onto the pole by gently pushing down on the seat.
