Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Wobbly chairs are not only uncomfortable, but often carry a safety risk.
This guide takes you through a method of reinforcing wobbly wooden chair legs through the use of metal L-brackets. Some level of experience with a cordless drill is preferable for this fix, though some minor handling instructions are covered in the guide.
Выберете то, что вам нужно
First, thoroughly assess your chair for loose elements.
Sit and jiggle them to test and note exactly what moves.
Position an L-bracket as if it will brace the leg to the frame of the chair.
Mark the exact outline of the bracket, taking extra care when marking the center hole where your screws will hold the brace in place.
Pre-drill holes through the center of your marked circles on both your chair legs and chair frame.
For extra hold and durability, use a small amount of wood glue at the chair legs joints.
Be sure to wipe away any excess wood glue.
Tighten any preexisting hardware holding the legs to the chair base before fixing the L-bracket to the chair.
Reassemble any remaining loose pieces as they were disassembled unless otherwise noted.
2 участников успешно повторили данное руководство.
Один комментарий
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
