Введение
This guide will show users how to fix the stretcher of an umbrella by using a thin piece of copper wire in place of where the rivet once was.
URL for half-hitch knot:
Выберете то, что вам нужно
Wrap the wire around the stretcher and thread it through the holes again.
Repeat until there is no more room to pass the wire through.
Use the scissors to trim the two ends of the wire to about half an inch in length.
6 участников успешно повторили данное руководство.
7 Комментариев
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
