Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Grab your broken tape measure and inspect so that it doesn't retract.
Remove the four 3mm Phillips #1 screws on the case around the clip.
Remove the 3mm Phillips #1 screw from the center of the clip.
Separate the two halves of the case by pulling them apart.
Begin unwinding your tape measure until you get to the end of the tape.
When the whole tape is out, slowly begin rolling it back in.
Roll it back in keeping your thumb firmly pressed on the wheel so that it goes back in smoothly and won't come out.
Once you start reaching the end, keep the tape straight with your thumb so that it retracts with no inconveniences.
Once you have rolled the tape in again, place the top back on making sure the tape doesn't come out or roll out by itself.
Begin placing the screws back in to their respective places and screwing them back in tightly.
Do this as you apply pressure on the top so that no parts come out.
Once your screws are back on, check your tape measure to see if it works properly or not.
If it isn't working the way you wanted to, repeat steps 2-7.
2 участников успешно повторили данное руководство.
