How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game
Выберете то, что вам нужно
  1. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game, Buttons: шаг 1, изображение 1 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game, Buttons: шаг 1, изображение 2 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game, Buttons: шаг 1, изображение 3 из 3
    • Remove the single screw from the battery panel using a Phillips head screwdriver.
    • Remove the battery panel from the device.
    • Remove the batteries using your fingers.
    • Caution: Battery acid on your skin can cause itching, pain, redness, and burning. Either wear gloves in the process or wash your hands after holding old batteries that have leaked acid.
  2. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 2, изображение 1 из 2 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 2, изображение 2 из 2
    • Scrub the metal battery connectors by twirling the steel brush to get a less dull color on the metal and have some luster to it.
    • Potential for device damage: Wash the steel brush after scrubbing the metal in the battery panel to avoid trapping any battery acid inside of the brush for future projects.
  3. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 3, изображение 1 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 3, изображение 2 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 3, изображение 3 из 3
    • Scrub and twist the end connectors of the Plug and Play against the brush so the tarnished/exposed surface can shine again.
    • Be sure to stick the whole connector into the brush to get inside of it as well. This is crucial to make sure that the connectors still work with the television.
  4. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 4, изображение 1 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 4, изображение 2 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 4, изображение 3 из 3
    • Remove three screws from the device using a flat head screwdriver.
    • Be sure to remove the hidden screw inside of the battery panel before separating to prevent any damage.
    • Remove two smaller screws from the device using a flat head screwdriver.
  5. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 5, изображение 1 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 5, изображение 2 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 5, изображение 3 из 3
    • Run your fingers around the side of the battery panel and separate the device in two.
    • Be sure to keep the joystick sideways to avoid losing track of the buttons' places; they will fall out because they are loose.
  6. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 6, изображение 1 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 6, изображение 2 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 6, изображение 3 из 3
    • Remove the buttons from the device.
    • If the buttons are stuck, use the pointed end of a spudger to pry the upper lip of each button.
  7. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 7, изображение 1 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 7, изображение 2 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 7, изображение 3 из 3
    • Install the replacement buttons.
    • Each of the three buttons has its own unique cuts on them so they should have their very own places to be set inside of the Plug and Play.
    • Potential for device damage: Do not force the buttons in place or they will get jammed again from repeated use.
  8. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 8, изображение 1 из 1
    • Press the yellow buttons on the board to make sure none of them were stuck down.
    • Pressing them will reset themselves from being out of place.
  9. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 9, изображение 1 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 9, изображение 2 из 3 How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 9, изображение 3 из 3
    • Put the two halves back together.
    • Reinsert the larger screws first to keep the game in alignment.
    • Place the battery panel cover into its respective slots and lever it flush with the bottom of the game.
    • Put back all of the smaller screws including the one in the battery panel.
    • There are six screws in total, one inside of the battery pack and five face up on the bottom of the game.
  10. How to Fix or Replace Buttons in a Jakks Pacific Plug and Play TV Game: шаг 10, изображение 1 из 1
    • Stick the ends into their respective color ports in the back of the TV!
    • Switch the channel and hope you can see the display with the nostalgic music playing back.
    • Game on and don't button mash to get the buttons stuck!
Финишная черта
Еще один человек закончил это руководство.
Garret Magalhaes
Участник с: 03/23/21
231 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team S1-G1, Gulbrandsen Spring 2021 Участник UMass Dartmouth, Team S1-G1, Gulbrandsen Spring 2021
UMASSD-GULBRANDSEN-S21S1G1
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 42
За всё время: 1,140
