How to Fix the Scroll Wheel of a Wired HP Mouse
Выберете то, что вам нужно
  1. How to Fix the Scroll Wheel of a Wired HP Mouse, How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 1, изображение 1 из 1
    • Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a Phillips #00 screwdriver.
  2. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 2, изображение 1 из 1
    • Gently flip the mouse back over and remove the upper half of the mouse casing.
  3. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 3, изображение 1 из 2 How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 3, изображение 2 из 2
    • Remove the broken axle that has become detached from the scroll wheel.
    • The broken axle may be difficult to locate, but should not have been able to leave the mouse casing unless it has previously been opened.
  4. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 4, изображение 1 из 1
    • Carefully remove all circuit components from the mouse and set on a flat surface.
    • The circuit board is a single unit that should be able to be removed easily all at once.
  5. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 5, изображение 1 из 1
    • Gently remove the scroll wheel by pulling it away from the rotary sensory mechanism.
    • The rotary sensory mechanism is the small green component of the circuit board that detects scrolling movement.
  6. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 6, изображение 1 из 1
    • Place the scroll wheel inside the jaws of the basic pliers such that the broken side is facing up.
  7. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 7, изображение 1 из 1
    • Holding the axle with a pair of small pliers, place a small amount of glue on the broken end of the axle.
    • Be careful to not get glue on yourself or any of the circuit components.
  8. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 8, изображение 1 из 1
    • Place the axle on the scroll wheel in the position of best fit, and allow to sit for several hours to dry.
  9. How to Fix the Scroll Wheel of a Wired HP Mouse: шаг 9, изображение 1 из 1
    • Return the scroll wheel to the rotary sensory mechanism.
    • The axle should sit over the middle mouse button input sensor which is directly across the circuit board from the rotary sensory mechanism.
Заключение
Еще один человек закончил это руководство.
William Riley
Участник с: 10/19/20
169 Репутация
1 руководство автора
Команда
Texas Tech, Team S14-G6, Cowan Fall 2020 Участник Texas Tech, Team S14-G6, Cowan Fall 2020
TTU-COWAN-F20S14G6
1 член
Автор 3 руководств
Один комментарий
Props for the effort, but this will not hold for long, glued plastic will snap again soon.
bxsus - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 108
За последние 30 дней: 510
За всё время: 11,274
