How to Hack Epson L200's Waste Ink Pad
Выберете то, что вам нужно
  1. How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: шаг 1, изображение 1 из 2 How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: шаг 1, изображение 2 из 2
    • A wild Epson Printer appears.
    • Turn it around and look for a small door.
  2. How to Hack Epson L200's Waste Ink Pad: шаг 2, изображение 1 из 2 How to Hack Epson L200's Waste Ink Pad: шаг 2, изображение 2 из 2
    • Locate the small door on the back and open it.
    • You will find the tube that drains the waste ink to the ink pad.
  3. How to Hack Epson L200's Waste Ink Pad: шаг 3, изображение 1 из 1
    • As you can see, the pad is full with waste ink and is larger than the small door that gives you access to it, meaning it is not meant to be changed by mortals.
  4. How to Hack Epson L200's Waste Ink Pad: шаг 4, изображение 1 из 2 How to Hack Epson L200's Waste Ink Pad: шаг 4, изображение 2 из 2
    • With a pair of tweezers gently pull the ink tube from the ink container.
    • Be careful not to grab it from the tube so as not to damage it.
  5. How to Hack Epson L200's Waste Ink Pad: шаг 5, изображение 1 из 3 How to Hack Epson L200's Waste Ink Pad: шаг 5, изображение 2 из 3 How to Hack Epson L200's Waste Ink Pad: шаг 5, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Desoldering Pump
    $3.99
    Купить
    • With the help of a syringe or anything that can suck liquid, clean the remaining ink from the tube.
    • I also went ahead and cleared the pad from as much ink as I could, it can buy you a bit more life span to the pad if you are in a hurry to print and not have the replacement items for this hack.
    • I did not have a syringe at the time and used a desolder pump, takes way longer though.
  6. How to Hack Epson L200's Waste Ink Pad: шаг 6, изображение 1 из 2 How to Hack Epson L200's Waste Ink Pad: шаг 6, изображение 2 из 2
    • Cut a 6" piece of the aquarium tubing and grab a connector.
    • Connect the printer tube to the aquarium tubing you just cut with the connector.
  7. How to Hack Epson L200's Waste Ink Pad: шаг 7, изображение 1 из 1
    • Put a connector on the end of the aquarium tube and connect it to the top of the bottle. Make sure that there is no chance of spilling or else you will have a big black spot of ink under your printer.
    • I inserted another connector on the top side of the bottle to release any pressure created by the ink coming in and the air in the bottle.
  8. How to Hack Epson L200's Waste Ink Pad: шаг 8, изображение 1 из 1
    • I placed the bottle in a lower elevation than the printer so that the ink can travel down the tube easier.
    • Check periodically to empty the waste ink bottle.
Заключение
17 участников успешно повторили данное руководство.
Angela Penaherrera
Участник с: 05/06/13
12 574 Репутация
Автор 5 руководств
13 Комментариев
I have the same problem. I will try that step. Good instructions. Thank you.
Adi Priyono - Ответить
Thanks for this! =) God bless!
CHRISTOPHER L. BIRUNG - Ответить
i need the ressetter for an epson l310
thandolwenkosim - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 29
За последние 30 дней: 146
За всё время: 54,037
