Введение
Do you have pants that need hemming but don't have a sewing machine to do it? Use this guide to help you hem any type of pants without using a sewing machine.
Выберете то, что вам нужно
Wear the pants and fold the hem up until you get your desired length.
Remove the pants, making sure that the folded hem remains fixed.
Lay the pants down on a table and measure the length from the original hem to the folded edge.
Turn the pants inside out, and unfold the folded edge.
Starting from the original hem, measure out the length of what will be your new hem.
Using your fabric marker, draw a line marking where your new hem would be.
Starting from the line you just created, measure out 1 inch and mark with a line.
Fold the raw edge up to the new hem line.
Fold it again along the new hem line, so that the raw edge is now inside the fold.
Place a sewing pin parallel to the fold to make sure that the fold stays in place.
Fold and pin all the way around to create your new hem.
Sew the fold close to create a new hem; try to keep your stitches small and even.
Once you're done stitching, tie off the thread by creating a knot towards the end of the string.
Cut off the excess string above the knot.
Remove all of the sewing pins.
Repeat steps 3 to 8 for the other pant leg using the same measurements, and then you're officially done!
18 участников успешно повторили данное руководство.
Один комментарий
Thank you for this guide! The only thing I am uncertain about is how determine a good length for the pants. I read in another guide that it would be good to measure with shoes on. So that the pant leg grazes the shoe. Can you recommend the same?
