Введение
Online shopping is great, but sometimes we get things that don’t fit us the way we had hoped. Shipping can be a hassle and sometimes you can’t return what you bought. So, why feel like you wasted your money? In this guide, we will show you step by step how to alter your large dress so that it can fit you perfectly!
All you will need for this Fast Fix is a dress that is too big, a sewing machine, some clothespins, and a pencil to mark the dress. If you have a darker dress we recommend that you use white chalk.
Выберете то, что вам нужно
Put on your dress.
Pinching the waistline, grab your ruler and measure from your hip.
Using your measurements from Step 1, measure out evenly from the seam line how much you need to take in on each side.
Now that your dress fits how you would like, carefully take it off and lay it back on a flat surface.
Using chalk or a pen, make a line that connects all the pins.
Thread your sewing machine.
Carefully push your dress through and begin sewing your new seam.
When you're done sewing your dress, flip it so that it is right side out and put it on.
If there is any excess fabric, you can cut it away, leaving 1/4 of an inch of the leftover fabric by the seam.
This is an easy and low budget way to fix a dress that is too large. Check the tag on the dress to see how you should care for it after. It is best recommended that you let your dress air dry.
Еще один человек закончил это руководство.
