How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board
Выберете то, что вам нужно
  1. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Access Door: шаг 1, изображение 1 из 2 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Access Door: шаг 1, изображение 2 из 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Front Bezel: шаг 2, изображение 1 из 1
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw (Right side of the RAM slot on 2105)
  3. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 3, изображение 1 из 3 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 3, изображение 2 из 3 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches. Or use two cards for the additional thickness.
    • If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
  4. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 4, изображение 1 из 2 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 4, изображение 2 из 2
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  5. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 5, изображение 1 из 2 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 5, изображение 2 из 2
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
  6. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 6, изображение 1 из 1
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  7. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 7, изображение 1 из 3 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 7, изображение 2 из 3 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 7, изображение 3 из 3
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  8. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Display: шаг 8, изображение 1 из 2 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Display: шаг 8, изображение 2 из 2
    • Remove the two 5 mm T6 Torx screws securing the display data cable connector to the logic board.
    • Pull the display data cable connector up off the logic board by its black pull tab.
  9. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 9, изображение 1 из 1
    • Peel back the EMI tape from the two vertical edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  10. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 10, изображение 1 из 2 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 10, изображение 2 из 2
    • Allow the lower EMI shield to hang down from the display.
    • Remove the four 7.5 mm T10 Torx screws securing the display to the rear case.
    • The screws are recessed, so a thin magnetic screwdriver aids in removal. Most bit drivers are too short to reach these screws.
  11. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 11, изображение 1 из 1
    • Lift the lower edge of the display and rotate it toward the top edge of your iMac.
    • Do not lift it too much, as the inverter cables are still attached.
  12. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 12, изображение 1 из 2 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 12, изображение 2 из 2
    • Disconnect both inverter cables from the inverter board.
    • These connectors are seated very tightly in their sockets. It is helpful to use your fingernails or the tip of a spudger to push the ears on either side of the connectors to dislodge them from their sockets. A small pair of hemostats helps a lot.
  13. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 13, изображение 1 из 1
    • Disconnect the two inverter cables at the top edge of the inverter using the method explained in the previous step.
  14. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board: шаг 14, изображение 1 из 1
    • Rotate the display until it is nearly perpendicular to the rear case and lift it up to peel it off the EMI shield stuck to its top edge.
  15. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Identify Make & Model Number: шаг 15, изображение 1 из 2 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Identify Make & Model Number: шаг 15, изображение 2 из 2
    • Lay screen on it's face. Locate the sticker on the back, which lists the Make, Model, and Model Number.
    • This screen, from a 2006 iMac A1207, is an LG model LM201W01. Yours Will Most Likely Be Different
    • The example searches shown in the next step use the model number LM201W01. Again, Yours May Be Different, so adjust accordingly.
  16. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Locate and Purchase A Video Driver Board for your Screen: шаг 16, изображение 1 из 3 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Locate and Purchase A Video Driver Board for your Screen: шаг 16, изображение 2 из 3 How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Locate and Purchase A Video Driver Board for your Screen: шаг 16, изображение 3 из 3
    • Using a search engine of your choice, search for the following phrase: "your-screen-model control board".
    • Other good places to find such parts are ebay.com and aliexpress.com.
    • Be sure that the control board which you purchase, comes with an inverter board for your screen's backlight.
    • Purchase the control board. Expect shipping times of 2+ weeks if ordering parts from Asia.
  17. How to Identify The Make & Model Of An iMac's Screen, In Order To Buy The Correct Video Driver Board, Purchase A Power Supply: шаг 17, изображение 1 из 1
    • The vast majority of control boards do not come with a power supply. Check the specifications listed by the vendor to get the power supply requirements for your board.
    • You'll need to get both the Voltage (typically 12v for 12-21" screens, or 19v for 24+" screens) and the Amperage. The control board's voltage specification must be followed exactly, while the amperage specification is a 'minimum required': In general, using a power supply with a higher amperage than the requirement is a good thing.
    • Shown here: A generic 12V 5A power supply purchased online for $8.
    • You may not need to purchase a power supply because you may already have one: check around your home or office for the unused power supplies of old electronics such as old modems, routers, coffee makers, etc. You may have one sitting in your box of spare/used electronics. Check before buying!
Заключение
What To Do Next
Congratulations! You have successfully identified your iMac's screen make and model, and ordered a control board and (optionally) a power supply for it.
If you are doing this guide as part of the "How To Convert An iMac Into An External Monitor" guide, return to that guide now.
4 участников успешно повторили данное руководство.
Olympia Mac Repair
Участник с: 02/07/10
892 Репутация
Автор 3 руководств
Команда
Olympia Mac Repair Участник Olympia Mac Repair
Business
1 член
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 88
За всё время: 4,620
