Введение
Unknown to the average user there are many different variants of the Galaxy S7. This guide outlines how to identify which rear camera you need in order to fix your Galaxy S7. If you replace the camera in your Galaxy S7 with the wrong type, you will get the "Camera Failed" message.
Выберете то, что вам нужно
Pictured left is a Samsung ISOCELL S5K2L1
Pictured right is a Sony IMX260
Currently different variants of the Samsung Galaxy S7 ship with different versions of the camera
These cameras are NOT interchangeable. A Samsung camera must be replaced with a Samsung camera and vice versa
Your handset will give the "Camera Failed" message if you replace the camera with the wrong type
This camera is identified by the lack of manufacturer identifiers
It has a green colored flex cable near the connector
This camera is identified by the "Sony" stamp on the flex cable
This camera has a blue colored flex cable near the connector
Another way to tell the difference without opening the device is using an application
AIDA64 can be downloaded from the Google Play Store
7 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
The Sony camera pictured here is for the S7 Edge. I tried it in my standard S7 and it failed. The correct S7 Sony camera has two lines of text on the flex. My phone is the 930V.
HERO_12M 2PD
SONY_V03C
Thank you JAmes, that’s exactly the info I’m looking for.
