How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429
Выберете то, что вам нужно
    1. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429, Glass Panel: шаг 1, изображение 1 из 3 How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429, Glass Panel: шаг 1, изображение 2 из 3 How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429, Glass Panel: шаг 1, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      Heavy-Duty Suction Cups (Pair)
      $16.95
      • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
      • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
      • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
      • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
      • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
      • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
      Спросите у FixBot
      Добавить комментарий
    2. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 2, изображение 1 из 3 How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 2, изображение 2 из 3 How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 2, изображение 3 из 3
      • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
      • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
      • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
      • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
      • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
      Спросите у FixBot
    1. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429, Display: шаг 3, изображение 1 из 1
      • Remove the eight T10 Torx screws securing the LCD to the outer case.
      • Be careful not to touch the display as the oil from your fingers may leave a residue that can be difficult to remove.
      • If necessary, peel the EMI gaskets located near the top center edge of the display assembly.
      Спросите у FixBot
    2. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429, Display: шаг 4, изображение 1 из 3 How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429, Display: шаг 4, изображение 2 из 3 How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429, Display: шаг 4, изображение 3 из 3
      $3.99
      • Carefully lay the iMac stand-side down on a flat surface.
      • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the first picture, we made one out of a bent paperclip. A pair of angled tweezers can also work well.
      • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
      • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
      • Raise and hold the display high enough to access the cables.
      • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
      Спросите у FixBot
    3. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 5, изображение 1 из 1
      • Disconnect the vertical sync cable in the upper left corner of the screen. Use the tip of a spudger to push on the connector's side tabs and gently walk it out of its socket.
      Спросите у FixBot
    4. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 6, изображение 1 из 1
      • This step brings your hands close to the exposed rear of the power supply. To avoid a high-voltage shock from the many large capacitors attached to the board, do NOT touch the rear of the power supply.
      • Disconnect the LED backlight driver cable with your hand by pressing the tab down and sliding it towards the bottom of the display.
      Спросите у FixBot
    5. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 7, изображение 1 из 2 How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 7, изображение 2 из 2
      • Pull the black tab straight up to disconnect the latch on the display data cable ZIF connector.
      • Do not pull up too hard or you will damage the connector and socket.
      • Continue to pull the black tab up toward the top of the device, to detach the display data cable.
      Спросите у FixBot
    6. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 8, изображение 1 из 1
      • Use the tip of a spudger to disconnect the display power cable next to the display data cable.
      Спросите у FixBot
    7. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 9, изображение 1 из 1
      • Carefully pull the display toward the top edge of your iMac and lift it out of the iMac case.
      Спросите у FixBot
    8. How to Install The Juicy Crumb Board iMac Intel 27" EMC 2429: шаг 10, изображение 1 из 1
      • Lay the display face down on a flat, soft surface.
      • If you are replacing the display panel, you will need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
      • If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
      • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
      • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
      Спросите у FixBot
      • Insert wisdom here.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Ben Capehart
Участник с: 06/09/21
10 263 Репутация
Автор 18 руководств
Команда
Global Fixers Участник Global Fixers
Community
68 членов
Автор 1 652 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 14
За последние 30 дней: 83
За всё время: 2,718
