Введение
This guide shows how to install a 2.5-inch hard drive into the aluminum enclosure sold by iFixit. The enclosure can hold either a SSD or a standard 2.5-inch (platter) hard drive, as long as they have the proper SATA connectors.
If you have a silicone enclosure, follow this guide instead.
Инструменты
Инструменты не указаны.
Запчасти
Use the included screwdriver to remove the two Phillips screws.
Set the drive in the plastic tray and align the drive ports with the tray socket.
Carefully push the drive into the tray socket to seat the ports.
Press the drive's raised edge down into the plastic tray.
Flip the drive tray over.
Use the a Phillips screwdriver to install the four mounting screws (included in the kit) to secure the drive to the tray.
Slide the tray back into the aluminum housing.
Reinstall the two Phillips screws to secure the tray.
Your drive is ready for use!
15 участников успешно повторили данное руководство.
