How to Install a Hard Drive Sled Adapter for Mac Pro First Generation
Выберете то, что вам нужно
  1. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Case Panel: шаг 1, изображение 1 из 1
    • Lift the lever to unlock the case.
    Спросите у FixBot
    Добавить комментарий
  2. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Anti-Static Wrist Strap
    $7.95
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
    Спросите у FixBot
  3. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Locate the Hard Drive Bays: шаг 3, изображение 1 из 1
    • Locate the desired hard drive bay after opening the case .
    • This is usually the drive closest to the front of the case.
    Спросите у FixBot
  4. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove the Hard Drive Bay: шаг 4, изображение 1 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove the Hard Drive Bay: шаг 4, изображение 2 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove the Hard Drive Bay: шаг 4, изображение 3 из 3
    • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
    • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
    Спросите у FixBot
  5. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove metal Hard Drive sled: шаг 5, изображение 1 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove metal Hard Drive sled: шаг 5, изображение 2 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove metal Hard Drive sled: шаг 5, изображение 3 из 3
    • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
    • Locate the four 6-32 type screws on the Hard Drive sled.
    • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
    Спросите у FixBot
  6. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 6, изображение 1 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 6, изображение 2 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 6, изображение 3 из 3
    • Insert the two tabs on the left side of the metal adapter bracket into the slots on the left side of the hard drive bay sled.
    • Align the holes on the right side.
    Спросите у FixBot
  7. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 7, изображение 1 из 1
    • Screw the two 7.8mm PH0 screws into the two holes on the right.
    • Leave these screws slightly loose; they will be tightened once the hard drive is attached.
    Спросите у FixBot
  8. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 8, изображение 1 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 8, изображение 2 из 3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 8, изображение 3 из 3
    • Align the holes in the hard drive with the three holes on the bracket.
    • Screw the three 6.1mm PH0 screws into the bracket and hard drive.
    • These screws can be secured tightly.
    Спросите у FixBot
  9. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: шаг 9, изображение 1 из 1
    • Tighten the two 7.8mm PH0 screws on the right side of the bracket.
    Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
Kristen Gismondi
Участник с: 11/12/14
107 779 Репутация
Автор 270 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 230 руководств
1 Комментарий к руководству
Tried installing these on MacPro5,1 today. Very disappointed. Sled does not slide into place correctly, and any attempt to nudge it into place only scratches the carrier.
Going back to OWC sled to mount SSD drives.
tjod - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 56
За всё время: 6,839
