Введение
If the vacuum is malfunctioning, water will be fed into the air pump causing it to rust and seize.
Выберете то, что вам нужно
Move the brewer so that the bottom is easily accessible.
Unscrew the five 4mm silver diagrammed screws using a #2 Philips Head screwdriver.
Using a spudger, gently pry open the base metal plate from the brewer.
Gently place the base of the brewer down.
Locate the vacuum apparatus within the Keurig B70 Platinum.
Using a #00 Phillips screwdriver, unscrew the three 15 mm black screws diagrammed.
Using a spudger, lift the white piece of the vacuum away from the black membrane.
Realign the circular pieces of the membrane so that the circles lie flush inside the black membrane apparatus.
14 участников успешно повторили данное руководство.
22 Комментариев
I cant get the little screws off of the vacuum. I broke 3 screwdrivers. Could they be glued?
After you take the white piece of the vaccuum pump off, you will see the black rubber diaphragm just below. DO NOT REMOVE the black rubber diaphragm. It is not necessary to remove this piece, and it will NOT BE POSSIBLE to re-assemble the pump after you remove it. Just clear any obstructions and put the white piece with the tube back on.
I removed the black diaphragm before I realized what it was, and now my Keurig K75 Platinum ($) is heading to the landfill. Hopefully this will prevent somebody else from making that same mistake.
Dang... didn't expect it to work... but it did!!
This worked for me. When i took off the white piece 2 of the 3 little rubbery, indented pieces were recessed and one was popped out a bit. I pushed them all in and it seemingly fixed the problem. I ran it about three times so far and it is working properly so hopefully it stays working for a while.
