Введение
This fix can be done without a sewing machine and instead be hand-sewn, however a sewing machine is recommended. The estimated time for this project is half an hour to 45 minutes. Allow extra time for seam ripping.
Выберете то, что вам нужно
Start by carefully ripping the seam of the pants with a seam ripper. Make sure not to leave holes in the fabric or it will show in the finished product.
Try on the pants. Have a partner pin the pants to the desired length.
If you do not have someone to help, measure the inseam of the pants and pin to the desired length.
Measure the width of the pant leg, double that measurement, and add 1.5 inches for seam allowance. Cut the bias tape to match this width.
Fold the bias tape underneath (about 3/4" -1") and iron flat. Make sure that the bias tape is not visible. Pin the two layers together.
2 участников успешно повторили данное руководство.
