Введение
This guide is to help lengthen a necklace chain in quick and easy steps. When doing this, we gave jewelry a more personalized style by completing and following our methods to lengthen the chain, making it more suitable. We completed this with a mix of repair methods that can be easily done with a few materials. Below we have provided our procedure, tools, guide, repair information, and further details on how to successfully lengthen a necklace.
Выберете то, что вам нужно
Measure and determine the desired length of jewelry chain that you want to add.
Place a piece of tape to mark where you want to cut.
Look at your jump ring. If there is no opening in the jump ring, carefully cut the ring yourself with scissors.
Use jewelry pliers to open the jump ring at one end of the extender chain and one end of the jewelry chain.
Connect one end of the extender chain to the jump rings.
Repeat the process by attaching one end of the jewelry chain to the same jump ring the extender chain is on.
With the jewelry pliers, carefully squeeze the jump ring shut, ensuring both the extender chain and jewelry chain remain securely attached to it.
Make sure that the extender chain's closure is secure and won’t open or come loose during wear. If everything seems correct, you are ready to wear it!
