Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Lay your garment on a table.
If you can, unzip the zipper.
Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
Pinch the slider in your fingers, so that you can see into the area where the coil rests.
Use the brush to free any dirt or debris caught inside the slider.
Twist open the Zip Care.
Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
Fold the paper towel over and dab any excess lubricant off the zipper.
Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
6 участников успешно повторили данное руководство.
