Введение
China is delicate and will often break due to daily use and careless handling. This guide will show you how to effectively mend plain, slightly broken china using a clear epoxy filler.
Tip: You can add any pigment to the epoxy, making the cracks less visible and the repair more subtle.
Выберете то, что вам нужно
Wipe all broken edges with rubbing alcohol using a paper towel.
Apply the epoxy along the edges of the base piece of china and first chipped piece of china using the toothpick.
Attach the first detached piece to the base carefully by hand.
Adjust as needed.
Attach the piece to the china.
Adjust as needed
Repeat the process of applying epoxy and attaching the chips until all broken pieces are successfully in place.
3 участников успешно повторили данное руководство.
