How to Open Your Logitech MX Anywhere 3
Выберете то, что вам нужно
  1. How to Open Your Logitech MX Anywhere 3, Soften the mouse feet adhesive: шаг 1, изображение 1 из 2 How to Open Your Logitech MX Anywhere 3, Soften the mouse feet adhesive: шаг 1, изображение 2 из 2
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. How to Open Your Logitech MX Anywhere 3, Disassembly information: шаг 2, изображение 1 из 2 How to Open Your Logitech MX Anywhere 3, Disassembly information: шаг 2, изображение 2 из 2
    • There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
  3. How to Open Your Logitech MX Anywhere 3, Remove the feet: шаг 3, изображение 1 из 3 How to Open Your Logitech MX Anywhere 3, Remove the feet: шаг 3, изображение 2 из 3 How to Open Your Logitech MX Anywhere 3, Remove the feet: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Repeat to remove the three remaining mouse feet.
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  4. How to Open Your Logitech MX Anywhere 3, Remove the case screws: шаг 4, изображение 1 из 1
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the two halves of the mouse together.
  5. How to Open Your Logitech MX Anywhere 3, Open the mouse: шаг 5, изображение 1 из 3 How to Open Your Logitech MX Anywhere 3, Open the mouse: шаг 5, изображение 2 из 3 How to Open Your Logitech MX Anywhere 3, Open the mouse: шаг 5, изображение 3 из 3
    • Gently open the top half of the mouse up and flip it over to the right, like a book.
    • Don't try to fully remove the top shell just yet—a cable connects the upper shell to the lower case.
  6. How to Open Your Logitech MX Anywhere 3, Disconnect the interconnect cable: шаг 6, изображение 1 из 2 How to Open Your Logitech MX Anywhere 3, Disconnect the interconnect cable: шаг 6, изображение 2 из 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  7. How to Open Your Logitech MX Anywhere 3: шаг 7, изображение 1 из 2 How to Open Your Logitech MX Anywhere 3: шаг 7, изображение 2 из 2
    • Pull the cable straight out of its socket.
    • During reassembly, insert the cable with its blue tab facing up, then flip down the locking flap.
  8. How to Open Your Logitech MX Anywhere 3, Remove the top half of the mouse: шаг 8, изображение 1 из 1
    • Remove the top half of the mouse.
Заключение
15 человек успешно провели ремонт по этому руководству.
Tobias Isakeit
Участник с: 03/31/14
119 458 Репутация
Автор 189 руководств
Команду
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 093 руководств
10 Комментариев
My left click started to have double click issue. Do you have any suggestions how to fix it? If I want to replace it, does ifixt have the part? If not, what is the part number? Thanks
Vim - Ответить
You could replace the left switch. See step 9 for the part number. You’d need to desolder the switch.
Sometimes it is enough to open the case of the switch and clean or tweak the small metal plate. But this is a very delicate finger exercise.
Tobias Isakeit -
Mine had the left click issue. Opening the switch case and cleaning the contact points resolved it.
Meo Tras - Ответить
Steps 6 and 7 are not necessary to get access to buttons (the most common malfunction). My model had this interconnect cable glued hard to the top half of the device. You can easily remove it without disconnecting the cable, oil the buttons and assemble mouse back
Максим Шилиманов - Ответить
My interconnect cable wasn't glued hard, but was attached via adhesive which took careful effort to peel away. I had to remove the screws on the board to get to the lower level to clean up coffee, though fortunately there was very little. However when I went to reassemble, I found a free spring and no clue where it came from. Thankfully, enlarging the third picture in step 5 shows where the spring is under the wheel assembly and I was able to reassemble successfully (also the two screws holding the wheel assembly are slightly longer than all others). I even managed to reinsert and restick the interconnect cable correctly.
Carol Y - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 48
За последние 7 дней: 235
За последние 30 дней: 1,133
За всё время: 18,038
