Введение
Use this guide to open the GuliKit KingKong 2 Pro controller for repairs and modding.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
Tilt your opening pick downwards to widen the gap.
Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
Slide the opening pick along the gap to separate the front assembly from the back cover.
Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
Separate the back cover from the front assembly and remove it.
