Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Press down firmly on the can.
Cut around the can with a utility knife.
Flip sample carpet onto its back and place down on a stable surface.
Place the can onto the sample carpet.
Trace the shape of the can with a marker.
Remove the can from the sample carpet.
Cut out the shape from the sample carpet using scissors.
Check to make sure the replacement piece of carpet fits into the hole.
Evenly spread glue on the underside of the replacement carpet.
Place the glue side of the carpet down into the hole.
Press down firmly on the carpet with your hand.
Trim carpet fibers to blend the replacement carpet with the original.
3 участников успешно повторили данное руководство.
2 Комментариев
Very good. I suppose if you don't have same carpet you can match as close as possible with a new piece.
Excellent tip - thank you for sharing!!
