Введение
Branches, sharp objects, or even standard wear-and-tear can cause holes and tears of many varieties to appear in your clothing. This guide serves as a resource to assist you in taking the steps needed to patch fabric on your clothing and restore your hoodie to working order again.
Before You Begin:
- Check the Damage: Ensure the hole is manageable for patching. Advanced techniques might be required if it's too large or near a seam.
- Choose the Right Material: Select fabric similar to the hoodie’s material and stretch for a seamless repair.
- Prioritize Safety: Handle sharp tools like scissors and needles with care to avoid injury.
Repairing your hoodie saves money, reduces waste, lets you personalize your clothes, and helps you learn a useful new skill!
Выберете то, что вам нужно
Identify the hole and measure a square that covers the damaged area, noting the length and width in millimeters (mm).
Before marking the new measurements on the replacement fabric, ensure that there is a quarter-inch gap on all sides.
Place a mark for each side of the previously gathered measurements.
Cut the replacement fabric along the marked dots, ensuring that the quarter-inch space before each mark is included in the cut.
Cut a length of thread that is approximately twice the perimeter of the square patch.
Thread the needle and tie a knot at the end to secure it.
Place the fabric over the damaged area, ensuring it fully covers the damaged area.
Begin a temporary stitch by inserting the needle in and out of the fabric at evenly spaced intervals to create a dashed line.
Once finished, tie a secure knot and cut the thread to free the needle.
Re-thread the needle with a new piece of thread and knot.
With a new colored thread, begin a permanent stitch with tighter spacing using the same technique.
Tie a knot and trim excess thread close to the knot.
Cut open the temporary stitch to remove it.
Once the patch is completely sewn, trim the patch as desired to ensure neatness.
Be sure to trim as desired should more strands of the patch become free. You now have a refreshed hoodie with a sturdy and stylish patch!
