Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Repairing a rip in vinyl furniture is a short, simple, and low-cost fit that can be accomplished in the home. Vinyl furniture can rip for a number of reasons, such as a sharp object or a pet scratching the material. It is best to repair a tear as soon as possible to avoid the tear becoming larger.
Выберете то, что вам нужно
Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
Let the adhesive dry for approximately four hours.
You may use a hair dryer to speed up the drying process.
Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
Apply light pressure to even out the edges.
Once the adhesive is dry, the furniture is ready for use!
4 участников успешно повторили данное руководство.
