Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the screen from the window frame and place it in your work space.
From where the tear ends, measure one inch from the left, right, bottom, and top of the tear.
Measure your patch using the dimensions determined in step 2.
If the patch is larger than said dimensions, mark where you will cut it.
Use scissors to cut the patch to size.
Place your patch over the tear to confirm it extends one inch from every side.
Using the pliers or tweezers, remove some threads from two opposite sides of the patch.
Stop when approximately half an inch of threads are exposed on each side.
Bend the exposed threads 90 degrees on both sides of the patch.
Center the patch over the tear.
Press the exposed patch threads through the screen.
Gently, but firmly, bend the threads back in the direction of the tear to secure the patch.
Do this for both sides, making sure the patch does not move around when both sides have been bent.
Check that the patch is secure and covers the tear well.
If the screen was removed from the frame, reinsert the screen back on the frame.
